Exploring Rolling Text on instruments possibility!!!
 I display a string on a powersupply, eg: LABVIEW , WHERE NOTHING IS IMPOSSIBLE , but as the powersupply is limited to display (12 characters at a time), what i see on display is LABVIEW , WH ., well..!! what i thought was to keep the character string rolling on the instrument and was stuck at this point , Any suggestions how this can be done..
Cheers,
Abhi
(3,094 Views)
Hi Abhi,
so you should just send 12 chars to the device. But you do this in a loop and with each next write command you increment the offset for the string subset function!
When you want to have a "rotating" text it can help to copy the first 12 chars of the string and append them at the end...
(3,087 Views)
Abhi,
I think one of the early Coding challenges, possibly on the now defunct LTR, was a scrolling text display. I don't have access to my archives form home today, but you might be able to find something by searching.
Lynn
(3,074 Views)
Hi Abhi,
maybe you want something like the attachment...
(3,070 Views)
