Exponential signal generator
I am a beginner user of LabView software, so I am asking for your help. Maybe someone has an idea how to solve this problem. I have to implement a virtual instrument that should generate a signal C(t)=C1(t)+C2(t)+noise; where Cn(t)=An*exp(-en*t). Assuming that C(t, T), because en (T).
Best regards
(1,551 Views)
Hi przemo,
So what have you tried so far?
Where are you stuck?
On your question:
What is "An", "C1", "C2"?
Which kind of noise?
What means "Assuming that C(t, T), because en (T)"?
Can you provide the correct formula by using a "professional" formula editor (like in MSWord) as an image?
(1,539 Views)
