Exponentially Modified Guassian Levenberg - Marquardt method
It's a relatively straightforward task to generate a Guassian in LabVIEW using a formula node with the following:
y=a*exp((-1)*(((x-b)/c))^2);
This makes it also easy to use the nonlinear Levenberg - Marquardt method vi to solve for a, b & c.
However, does anyone know of a similar method to use the L-M method to solve for an Exponetially Modified Guassian (EMG)? Specifiaclly, is there a way to either a) incorporate an integral with programmable boundaries or b) use an error function when writing an equation in G?
2006 Ultimate LabVIEW G-eek.
(2,559 Views)
Just to answer myself, in case anyone else deals w/ this...
The trick is to use a polynomial expansion or other numerical approximation in place of the erf.
(2,559 Views)
