Export Adaptive Filter Toolkit Algorithm To C Using LabVIEW C Code Generation Toolkit
I want to evaluate the performance of some of the standard adaptive filters & have planned to use "Adaptive Filter Toolkit" from NI. Once the desired adaptive filter is selected I want to implement the same filter algorithm in FreeScale controller.
I understand that LabVIEW C code generation toolkit exports the LabVIEW code to ANSI C code. However, I'm interested in knowing if this toolkit would be able to export Adaptive filter toolkit algorithm as well (since the underlying IP would be in the form of DLL's).
Any help on this matter would highly be appreciated !!
Message 1 of 1
(2,671 Views)
