Export KML File to Google map
I made a KML file with GPS data.
Now,I'm trying to send it to Google map using labview.
Any ideas ?
(3,844 Views)
could you be more precise in your description ?
What do you want to know exactly ? How communicate with google map from LabVIEW ?
Is it how to open a KML file in google map with LabVIEW?
(3,815 Views)
Hello Alexis_J,
Thank you for your reply.
Here's what I did:
1. I made a KML file with data received from GPS in labview.
2. I integrate a map in labview .
Now , my problem is how communicate with them to visualise the position.
Tell me if this still not clear.Thank you.
(3,809 Views)
Ok ok.
Thank you for your reply too.
So, it's more clear but, if I reformulate, you want to put like a map pointer in your map it's right ?
(3,796 Views)
