Export TestStand Sequence File Documentation Using LabVIEW
I am looking to create a LabVIEW application that will export the sequence file documentation of any given TestStand sequence. So far, from what I can tell, this may not be possible?
(1,361 Views)
I have done something like this in the past, so yes, anything is possible using the TestStand API through LabVIEW.  Basically in a nutshell you want to get a reference to the sequence file and then each sequence and then each step. Extract the information and present it a nice pretty format.
There used to be a sequence documenting utility directly from TestStand that would do something like this.
Before going any further, what documentation are you looking for?  Step names, Limits, VI Names?
PH
(1,329 Views)
