Export Waveforms to Spreadsheet Extra Lines
Glad to see someone else saw this problem. I thought I was going crazy too. Interestingly, I found that if you have multiple time columns (i.e. by setting the "Multiple Time Columns?" property to True) the VI doesn't cause this behavior. It's only if you have a single time column that blank rows are inserted after each write.
Does anyone know if this has been noted by the labview developers for future fixing? This definitely seems like a bug (though minor) that should be fixed. If not, perhaps the best way to get the developers' attention would be for me to open a new discussion and reference this one.
Message 11 of 19
(2,513 Views)
I do not see a fix for this listed in the 2009 SP1 release, and this behavior got missed on our monthly bug thread in the Breakpoint forum. I don't know if a CAR was ever issued.
I agree it's a bug that should be fixed.
Message 12 of 19
(2,503 Views)
A CAR has been filed for this and R&D is working on it. In the mean time, there is a workaround.
1. Open up the Export Waveforms to Spreadsheet VI and go to the block diagram.
2. Remove the Increment function that comes out of the shift register (bottom left hand corner of the block diagram). This should be wired straight through without the increment.
I would recommend saving the VI under another name, so that the original remains untouched.
Does this resolved the issue for all of you?
Have a great day!
Tanya Visser
LabVIEW Group Manager
Message 13 of 19
(2,485 Views)
Can you post the car number?
Message 14 of 19
(2,477 Views)
The CAR number is 44310.
Tanya Visser
Message 15 of 19
(2,469 Views)
Thanks...Smiley Wink
Message 16 of 19
(2,459 Views)
That works great, Thanks!
Message 17 of 19
(2,190 Views)
this issue remains unfixed. tested labview 2016 still adds an extra line with empty fields
Message 18 of 19
(2,043 Views)
Still an issue with LabVIEW 2020
Randall Pursley
Message 19 of 19
(1,462 Views)
