Export data from excel and plot graph in labview
hi,
i manage to export data from excel to labview and read it. but i do not know how to plot it in graph. Attached are the excel file, vi and image. can anyone help?
(4,016 Views)
attached are the files.
(4,011 Views)
Are you trying to use LabVIEW to create a graph in LabVIEW or on the Excel worksheet?  I think I posted an example doing this in Excel a few months ago.  If you are trying to make the graph in LabVIEW, then you should be "all done" -- you read your data, now just use LabVIEW's Graph or Chart indicator and wire your data to it.
(3,850 Views)
i am trying to plot the graph in Labview. i tried use LabVIEW's Graph or Chart indicator and wire your data to it but i does not work. i does not allow me to connect. can u help me on that?
(3,826 Views)
I found this example which use Report Generation Toolkit:
https://decibel.ni.com/content/docs/DOC-4965
Hope this helps!
Simyfren
(3,810 Views)
