Export data to file with OSC Server-FPGA
I'm using OSC Server-FPGA vi and I want to export data to text or Excel file.
I tried the configuration that  is shown (I marked it) in the attached image, but no file is created.
What do I need to do to export the data?
Thank you.
(2,617 Views)
Hi sagishy,
- you should use error cluster wires. Anywhere!
- you need to provide the correct path! Which one did you supply?
- What is the target the VI runs on? Is it your PC or is it some RT target (like a cRIO)? Did you choose the coorect file path for that target?
(2,608 Views)
