Export to excel from express VI table is not working
@Zaqf wrote:
Since I'm using compactrio 904x I won't be able to save it on my PC or desktop. Where do I save it ? Any idea ?
Of course not.  The cRIO is a completely different computer from your desktop.
This seems like the first time you ever mentioned a cRIO!
Message 41 of 64
(1,472 Views)
Yea. It's been so many days I've trying to sort this out , please help me find a file path as well, I need a waveform graph of one of the AI channel , buh when I connect the the graph, I'm getting the graph of both the channels with single plot.
Message 42 of 64
(1,470 Views)
Use an index array to get out whichever of the two channels you want.
Since your data is equally spaced in time, you could use a waveform graph if you have the whole data set of values, or a waveform chart which allows you to add a data point at a time since a chart maintains a history of the data that came before it.
Message 43 of 64
(1,471 Views)
Please don't start several threads on the same topic!
Message 44 of 64
(1,469 Views)
Is it okay if I just connect a pen drive to the Crio device , and copy it to them ?
Thank u.
Message 45 of 64
(1,453 Views)
Yes.
Just use the correct path!
(Read the manual of your cRIO carefully...)
Message 46 of 64
(1,464 Views)
Index array connected before the first built array yeah ? And then connected to the graph ? Could you please enlighten me in detail.
Thank you
Message 47 of 64
(1,445 Views)
Edit: deleted wrong content…
Message 48 of 64
(1,440 Views)
I can't work out which VI you're currently using (the most recent "daqmx latest model MOD.vi" has no graph, and uses random numbers to create the results), but it seems very likely that if you use Index Array before the first Build Array, then you won't have an array and it won't produce a valid run arrow.
Probably using Index Array immediately before the current graph (guessing) is what was intended.
GCentral
Message 49 of 64
(1,440 Views)
Yes , it is the same VI. I've connected the channels instead of random numbers and I just need a graph of one of the channels.
 Please help.
Message 50 of 64
(1,433 Views)
