Export waveform to spreadsheet
Hai... I was tryin to write a waveform to spreadsheet obtained from an accelerometer through DAQ usin labview.... Since i'm using a loop it keeps on askin the file name... Is there any way to save it in a single file or give the file names previously.... could someone please help...
Message 1 of 10
(5,541 Views)
Accepted by topic author preethip
There are many alternatives to do this. You may use a "Path Constant" if you know the file location or get the path from reference. It will be easy to explain if  you could post your code so that i can specifically tell you , what is required in your code..
Nitzz
(Kudos are always Welcome, Accept as a solution if it is the One;))
Message 2 of 10
(5,536 Views)
May be you can refer the example attached.
Nitzz
(Kudos are always Welcome, Accept as a solution if it is the One:smileywink:
Message 3 of 10
(5,531 Views)
Hey that worked... But its asking whether the file should be replaced... i want to save data for some time ... so is it possible that i can save it in multiple files or append all data to the same file....
Message 4 of 10
(5,529 Views)
In the file I sent you, I had made it for appending data.. Wire a true constant to the "Append to file?" terminal of write to spreadsheet function. It will append the data every time..
Nitzz
(Kudos are always Welcome;))
Message 5 of 10
(5,526 Views)
Thanks a lot.... Writin to a spreadsheet is working but i need to write a waveform to  the spreadsheet... Its asking continuously if i should replace the file when i use it.... could u please help...
Message 6 of 10
(5,524 Views)
Kindly post your vi if you dont mind..
Nitzz
Message 7 of 10
(5,522 Views)
Hey thanks a lot :).... It worked...:)
Message 8 of 10
(5,519 Views)
Oh , thats good.. I am glad.. by the way, thanks for so many kudos:)
Nitzz
Message 9 of 10
(5,509 Views)
I really appretiated the solution. I am just begining to use LV and I want to store information that i collect (mostly Voltage and Current Readings) to a spread sheet for each trial I run. I want to add a time stamp to each and possibly a header. How would I format the spread sheet to include information other than that data?
-Tom
Message 10 of 10
(5,490 Views)
