ExportVIStrings removed from LV 8.2?
We are using .Net to read values off a LabVIEW panel via COM - This is pretty straightforward.
In LabVIEW 7 we use the ExportVIStrings  COM command from .Net to dump the contents of the front panel to a text file and we  would get the control names from this file.
It appears that this command has been removed from the COM interface for LV 8 and not replaced (as far as i can see). I can resort to using the PrintVIToText command, but this is not at useful and would mean rewriting a fair-sized chunk of code.
Am I missing something or is there a better way to get a list of the front panel controls from another programming language (c#, vb, c++ etc).
Matt
(2,753 Views)
"mjclarke" <x@no.email> wrote in message news:1175254806676-499924@exchange.ni.com...
We are using .Net to read values off a LabVIEW panel via COM - This is pretty straightforward. In LabVIEW 7 we use the ExportVIStrings&nbsp; COM command from .Net to dump the contents of the front panel to a text file and we&nbsp; would get the control names from this file. It appears that this command has been removed from the COM interface for LV 8 and not replaced (as far as i can see). I can resort to using the PrintVIToText command, but this is not at useful and would mean rewriting a fair-sized chunk of code.Am I missing something or is there a better way to get a list of the front panel controls from another programming language (c#, vb, c++ etc).Matt
I'm not sure if it's exported or not, but the position of the ExportVIStrings has changed.
It's now under "VI Strings>Export", in stead of "ExportVIStrings". Perhaps you'll see it as "VI Strings.Export".
Hope it helps.
Wiebe.
(2,749 Views)
Thanks for the reply.
Unfortunately, VI Strings does not show up through the COM interface either.
Matt
(2,743 Views)
Hello Matt,
I have taken a look at this issue and I experience the same behaviour. This has been escalated to our Research & Development team who will deal with the problem. As soon as there is any information available regarding this I shall post it on this forum to let yourself and anybody else with the same or similar issue know what National Instruments recommends as a course of action.
Let it be known that this is only experienced in LabVIEW 8 & 8.2, and selecting the LabVIEW 8.2 Type Library as an Automation reference within LabVIEW 7.0 / 7.1 doesn't display the same behaviour.
The help file for the VI Method (ActiveX) in LabVIEW 8.2 can be found online here for future reference.
Tom
NIUK
(2,713 Views)
