Exporting Shared Variables to csv
When I try and export SV information to csv, LV (2009, DSC) doesn't seem to recognize any variables that are located within virtual folders in the library. Does anyone know a work-around to get that data tabulated short of cycling through the whole library writing values from SharedVariableIO property nodes to file?
Kyle
CLD using LV, DSC 8.5-2009, RT 8.5
Ghoti!
(3,300 Views)
(3,287 Views)
muks wrote:
Have you seen this?
Yep. That's the problem. The shared variable library I'm working with contains well over 1000 variables that are organized into a few dozen virtual folders within the library. When I use the Export Variables function you linked to, it doesn't "see" any variables in folders, only those in the library root.
Ghoti!
(3,271 Views)
