Exporting Waveform Chart to Excel with only One X Column
Ok, so I've been messing with this build waveform.  I've got it to do something.  But now I'm running into the issue of having two plots on the same graph.  So I think I'm running into the classic issue of not knowing the difference between charts and graphs, etc.  Also, I'm trying to update the chart in Real Time.  So each individual point is then put into a build array and I build the waveform from there.  That doesn't sound like the right way to do that.
I've attached my spaghetti code
Message 11 of 12
(1,217 Views)
Scaling was the answer.  Divide test time by iterations and scale the X - Axis by that multiplier.  Someone might have mentioned that.  But that's the answer.
Message 12 of 12
(1,199 Views)
