Exporting front panel graph to clipboard
I want to export Graph (not simplified image, but exactly as in front panel) to clipboard. Then, I will paste the clipboard content to MS Word document.
How can I export that graph image to clipboard?
Thank oyu.
Message 1 of 11
(7,914 Views)
Hi it can be done using an invoke node. This VI has been saved for LV 8.0
LabVIEW 8.2,8.6,2009...still learning 😛
Message 2 of 11
(7,903 Views)
Thank's for your response. The ExportImage method doesn't keep the properties of the graph. In other words, exported image is simplified image. What I want is exactly the same as displayed on front panel ( color, cursor, etc).
How can I get that result?
Message 3 of 11
(7,899 Views)
Pick "Data Operations->Copy Data" in control shortcut menu. Then go to WORD and paste it (Ctrl+V).
Copying FP image is available for all controls besides graphs.
Message 4 of 11
(7,890 Views)
Hi, sorry missed that point. The copy data option advised by hanrock can do that.
Message 5 of 11
(7,883 Views)
Ooops, I am very sorry. My question was incomplete. I want to do that programmatically.
So?
Message 6 of 11
(7,879 Views)
O.K. Then my example is to use a 2D Pic control to export the image.
Message 7 of 11
(7,871 Views)
Hi Hanraock,
I'm using LV 8.2. Would you please convert to LV 8.2? Can I run that code in LV 8.2?
Many thanks.
Message 8 of 11
(7,862 Views)
Sorry, yoppy. You need to at least use LV8.5 since the 2D Pic export invoke is introduced in LV8.5.
Message 9 of 11
(7,860 Views)
Accepted by topic author yoppy
If you work on Windows, you could also use the library in the attachment of following post.
Rolf Kalbermatter  My Blog
Message 10 of 11
(7,855 Views)
