Exporting graph as image
Is it possible to export a graph from the front panel as an image in TIF format???
(4,944 Views)
I believe BMP is the only option.
=== Engineer Ambiguously ===
(4,920 Views)
Export Image Method: Exports an image of a waveform graph to the clipboard or disk.
Ref: http://digital.ni.com/public.nsf/allkb/5AE4ADCBB65A6D8F86256FBF007A1AC1 and http://zone.ni.com/reference/en-XX/help/371361L-01/lvprop/waveformgraph_exportimage/
- Any reason why only tiff you are insisting?
File TypeYes
Specifies the format of the file. You can export into one of the following formats:
(Windows) .emf, .bmp (default), and .eps files
(Mac OS X) .pict, .bmp (default), and .eps files
(Linux) .bmp (default) and .eps files
uday
(4,909 Views)
While i am exporting as BMP and copying it to a PPT the curves looks a bit distorted. To resolve this issue one of my friend suggested exporting in TIF format.
(4,881 Views)
Well I don't make Powerpoint presentations that often, but it sounds like when you paste it in Powerpoint is resizing it to fit on your slide, but it's not maintaining the aspect ratio.
I really doubt pasting a TIFF would make any difference.
Ty resizing it first on another program then paste it into Powerpoint
(4,878 Views)
Thanks for the reply... I will try that and get back to you on this
(4,875 Views)
Or you could always use another program to conver it to a TIFF first too.
(4,873 Views)
