Exporting graph to MS Excel
Hi everybody,
Can anybody tell me how to export graphs to MS Excel table?
I have Labview 8.5 I found few example at the internet but with earlier version.
Regards
Message 1 of 18
(7,404 Views)
Post the example here so that somebody will convert it for you.
[Edit: Or just give the link here instead of attaching the file so as to reduce the attachment size thereby saving the forum space.]
Message Edited by mathan on 03-04-2009 06:11 AM
Message 2 of 18
(7,399 Views)
Here is the file attached
Message 3 of 18
(7,396 Views)
Hai,
It was saved in 8.5 only. I have no problem in opening it with 8.6. So am sure it will also open in 8.5
Message 4 of 18
(7,390 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=377586&query.id=123310#M377586
here our sir dennis posted some nice info. go through it.
Mathan
Message 5 of 18
(7,387 Views)
I do not know how to export the graph into MS Excel ?
This is my issue files I found in the internet to export to MS Excel are Labview 5
Regards
Message 6 of 18
(7,383 Views)
I saw the link and I tried to put Export Waveforms to Spreadsheet File.
It gave me error< I do not know why ?
Please check attachment
Message 7 of 18
(7,365 Views)
What error? Aside from the fact that you left the filepath unwired, which causes the Export Waveforms to Spreadsheet File to ask you for a file name each time the loop iterates, the VI saves the data to file. Are you expecting to get an Excel workbook? Well, you won't. That VI (and the Write to Spreadsheet File) do not create Excel workbooks. They create text files. If you want to save the data to an Excel workbook then you need to use ActiveX (or ADO). There are examples that ship with LabVIEW on how to use ActiveX to control Excel. In fact, there's a shipping example called "Write Table to XL". You can find other examples in the Excel thread.
Message 8 of 18
(7,355 Views)
Well, I tried to do but unfortunatly, I can not and I did not fully understant what you said Smiley Sad
Message 9 of 18
(7,333 Views)
Hi sky1981,
do you need a "real" Excel file with different workbooks? If yes, then you have to use ActiveX or ADO as mentioned by smercurio_fc. If you need a spreadsheet file which can be opened by Excel, then you can use the function in your example.
Hope it helps.
Mike
Message 10 of 18
(7,321 Views)
