04-25-2012 01:41 PM
I need this for documentation. Is there a way to export a list of states from a case and event structure to a text file? Thanks.
04-25-2012 02:42 PM
Steve,
If you enable scripting you can do it like this:
Then write the names to a file.
Enable scripting nodes under tools>>options>>vi server
Dont forget Kudos if this is what you were looking for ![]()
Michael
04-25-2012 03:21 PM
You can do this for a case structure. You cannot do it for an event structure. I know of no programmatic way to get event structure names/events.
04-25-2012 06:45 PM
04-26-2012 05:35 AM
I've (somewhat) succeeded using OCR to retrieve the events from an Event structure here.
