Exporting waveform
Im having a problem with expotring waveform to .txt file.When I export it,
time division is not quite clear.I mean,I am getting my waveform,but LabVIEW
exports date,hours,seconds and so on.I would like just to have miliseconds
on my x-axis.How to tell LabVIEW to do it??
Thanx!!!
(2,896 Views)
I believe there is an option for changing the time units if you right click on the graph, choose the X-Axis submenu, and then choose Format. In here, you should be able to select what parts of the time you would like to see. For instance, you can turn off the years and have the time start at 00:00:00.
Pete
(2,896 Views)
