Express 7 Student Edition Question
Hello:
I'm playing around and learning LabView. I bought a copy of LabView 6i
Student Edition and found that it didn't support the advanced data
acquisition instruments (I wanted to used the continuous data
acquisition example and it wouldn't work). Does anyone out there know
if the new Labview 7 Express Student Edition supports all of the
features or if it's somewhat crippled like 6i? Any info would be
greatly appreciated, as I'd like to avoid spending another $70 if it
doesn't.
Thanks!
Dan
(2,789 Views)
I believe the Student Edition of 7 is fully functional. It adds a tag in the lower left corner of the windows identifing it as the student edition.
To be sure, you should call NI support and verify.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,789 Views)
The student version should be equivalent to LabVIEW Full but with a watermark on the front panel and block diagram. I think 6i had a special daq driver, but according to the web, 7 uses the standard daq driver. See Which DAQ boards are Supported when Using LabVIEW Student Edition?
(2,789 Views)
