Express DAQ Input & Cluster Unbundel
Hi guys,
I have a question about using the express daq function and cluster management.
I need to sample from ni 6501 from ports 1.4..2.7 total of 12 Inputs.
So with the express DAQ Digital input (line) option I'm selecting Ports 1.4..2.7 total of 1 lines.
Then I want to convert the sample to cluster and unbundel io 12 samples....
The problem is that when I'm doing unbundel I see only 10 samples of (T/F)
Any ideas?
Pic attached.
Kobi Kalif
Software Engineer
(2,619 Views)
Hi not need to answer i ave found the sulotion in setting the cluster size at the convertion.
Kobi Kalif
Software Engineer
(2,605 Views)
The conversion of an array to a cluster to unbundle individual elements has unnecessary steps  It is a Rube Goldberg.
Just use Index Array.  Drag the bottom of the Index Array Function downward and you will get multiple outputs.  By default, the first is element zero, and the rest are all in sequential order.
(2,593 Views)
