05-24-2018 02:45 PM
Is it possible to distribute/use an express VI in a packed library?
I have developed a central error handler for use in a large application, based on the CEH developed by NI, which I modified to use user events and work across packed libraries (in principle). The re-entrant express VI for configuring errors is really useful! However, I can't get it to work outside the LabVIEW directory. I've tried moving the code to my source code directory, building menus, packaging the menus in a packed library, linking the new menu to the palettes in LV, but none of this works. Looks like I'm backing up and using another error handling approach.
05-25-2018
03:41 PM
- last edited on
01-12-2026
09:47 AM
by
Content Cleaner
Hello Little Spaeroid
According to this you should be able to generate a packed library just by adding it to the project. However, Express VIs do not work like this since they are not added to the project when you include them. Perhaps what you can do is opening the Express VI front panel and convert that express vi into a normal VI. I think this is possible by opening the front panel of the express vi and saving it as a new name. Be careful though, if you do any changes to the VI make sure you same it under a new name. If you same it on the same name it may affect the next time you try to call that Express VI.
I hope this info helps you,
Have a nice day,
Sebastián Ramírez Sandí
NI AE
05-29-2018 11:24 AM
Thank you, I also came to the conclusion that the answer was no.
