Express XY Graph Multi-plot Cursor point
       In mixed signal graph >> Property >> Cursors Tab >> Enable Allow dragging here if we select Multi-plot, it will show X scale and all Y-scale value in Cursor legend.
How can I get these same options in Express XY Graph?
Sivaraj M.S
CLA
(3,404 Views)
You need to use a property node and find the curser position and then plot those points in a seperate xy plot (only it will be one point instead of an array). You will still have to plot it as an array of one point.
Tim
GHSP
(3,376 Views)
