Express XY plot - Overplot timeline
I tried to plot a graph using the XY Express. The X axis is a timeline.
The problem starts to occur after 5 minutes. The X axis (timeline) doesn't move itself, but for instance, there is no problem if the timeline axis moves. The past is not too important for me, only two minutes of history, I have to check and analize.
You can view what is occuring as showed in the attached pictures.
How can I solve this problem?
(3,985 Views)
Is there anyother type of graph that I can use to do this job? If anyone has an example, it would be a good idea to share it with me.
(3,968 Views)
Can you reproduce this in just a simple VI?  Perhaps these screenshots are already from a simple test VI.  Regardless, if you could post the VI that would be most helpful in trying to understand what's going on, thanks!
(3,963 Views)
Hi Jeff!
If you look at test2 picture, you will see that after some time, the graph returns to the begining and the old data was not erased. I would like to have a graph that the timeline (X axis) is fixed in 2 minutes, for example. So, while the time is passed by the X axis follows it.
Do you understand the problem? I am a beginner, it should be a simple question but, maybe I am not clear enough to explain it.
I don't have the example to show you, but I will try in one to show you.
Thank you in advance.
(3,959 Views)
I'm sorry, no, I don't understand the problem.  While I could make certain assumptions, without knowing what the VI looks like that generated those graphs, I don't see how it'd be possible for anyone to understand the problem.  A VI would be helpful.
(3,941 Views)
The explaination:
There is a streaming that I connected to an Express XY graph. This streaming is linked to Y axis. The X axis is the timeline.
The problem is that after some time, as you can see at test2.jpg the time was 00:04:10 and in the instant after that it was 00:00:00. The X axis is receiving a timestamp data, that does not goes back to the past, so, this is the problem. Why the timeline is going back to the past?
Is there a solution for this problem?
Message Edited by gborges on 06-30-2006 09:36 AM
(3,932 Views)
