ExpressVI prompt user for Input dialog floating
I am using ExpressVI "prompt user for Input". The question is, when the dialog window pops up for input, I cannot activate other windows .
So how can I change this expressVI's dialog window to floating windows appearance?
(2,730 Views)
Short answer: you have to make your own.
You can start with the Express VI by right-clicking on the express VI and selecting "Open Front Panel" and click "Convert". This will create a brand new VI that is the equivalent of the Express VI. Save the VI under a new name within your project hierearchy, and then change the properties on the VI from a modal to a floating:
  1. Select File->VI Properties.
  2. Select "Window Appearance" from the pulldown menu.
  3. Select "Custom" option and click "Customize...".
  4. Select "Floating" in the "Window Behavior" section.
(2,719 Views)
Thanks. I got it.
(2,706 Views)
