Extended Ascii on JSON
I have a JSON setting file witch is loaded from my .VI
My JSON is like this:
I need to write the charactère 0x00 which is \u0000 but when I do that labview can't interpret it:
It replaces all the data by "?".
Here is my the labview structure I use:
Do you have a fix?
Thanks for taking a look at my situation.
(3,933 Views)
Accepted by topic author Nalofox
The standard JSON functions that come with LabVIEW have a known bug of truncating strings at the first zero, even if that zero is properly represented as \u0000.  You will need to use a different JSON library, such as JSONtext (which I wrote).
BTW, you shouldn't need to do all that utf8 conversion; the JSON functions should handle that.
(3,891 Views)
Thanks for your response.
So I have used the lib you tell me JSONtext and it works well,
Here's is my labview (there may be a better way to do this).
Have a good day
(3,857 Views)
Hello, I'm beeing using the JSONtext library for a while and I'm still having issue with the "From Json text.vi".
The VI does not convert properly Extend ASCII format. Those caracter are convert to "?"
Is there a way to force the VI to convert correctly?
(2,841 Views)
I have used JSONtext in the past for many JSON things I run into, but I have found the same thing as you when trying to import text using upper ASCII in it.
To be fair to the JSONtext library I have been using an old version (1.4.4.89) so it may be better now.  There are some things in recent patch notes I see about Unicode which might also imply support for upper ASCII.
On an application where I encountered upper ASCII, I used the "i3 JSON" toolkit instead:
https://www.vipm.io/package/i3_json/
It's not as easy to use and seems to be a bit slower, but it also didn't have a problem with those extended characters.
So I would try first seeing if you have an updated version of JSON text and if that doesn't work, try the i3 library.
(2,833 Views)
Your problem lies with whatever produced your psuedo-"JSON" string, as JSON is always UTF-8 encoded.  Interpreted as UTF-8, your string has invalid characters, that show up as question marks when JSONtext tries the convert the "UTF-8" to extended ASCII.
If you can't fix the bug in the code generating the input string, try converting it to UTF-8, using the (off-pallet) conversion function:
(2,805 Views)
