External CSV Reader package
"Read Delimited Spreadsheet" works fine for plain numeric data... but croaks when trying to read string data that is surrounded by quotes containing a comma. For example the CSV file:
Date/Time,Value
"Aug 31, 2:00PM",42
would return 3 columns:
"Aug 31 | 2:00PM" | 42
Quick google hunt didn't find anyone haven written a package to do this. Sure, I can do it myself but I figured I'd take the lazy "maybe someone has already done it" approach first.
(1,341 Views)
Date/Time,Value
"Aug 31, 2:00PM",42
Everything is going to treat a comma as a separator in a file that is supposed to contain Comma Separated Values.
You could try setting the separator to " if that's what is actually separating the values in the file.
Otherwise post a sample of the data file you are working with maybe we can come up with a more elegant solution.
=== Engineer Ambiguously ===
(1,331 Views)
Yep. CSV stands for Comma Separated Value. Got it.
CSV standard allows for string fields to be enclosed in double quotes
"Aug 31, 2:00PM"
In those cases, every CSV parser in another language (Excel included) reads the comma enclosed in double quotes as part of the string field, not as a separator.
(1,314 Views)
Accepted by topic author BowenM
(1,292 Views)
Hunted VIPM, don't know how I missed it.
Thank you!!
(1,271 Views)
Silly me didn't believe Excel was that smart... sure enough, it works as described! 😳
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
(1,081 Views)
