External Excitation with NI 9218
I have two load cells which require the excitation voltage of 5V and NI-9218, however NI 9218 is capable of providing only 2V and 3.3V in bridge mode and 12V in Voltage mode. I am trying to provide 5V excitation voltage external Voltage externally using a power supply, however when I select the Excitation Source as external I get the following error:
Requested value of the property AI.Excit.Src is not supported. Possible Value: Internal
How can I use External Excitation source with NI-9218 to measure strain?
(902 Views)
Hi linu,
Why don't you use the 3.3V excitation?
Do your load cells really require exactly 5V?
(887 Views)
It does not require exactly 5V, but output that I am receiving is very low. The datasheet mentions recommended excitation as 5V to 10V. Can someone please explain how does changing the excitation voltage affect the output.
I have two load cells 1kN and 0.5kN each.
(826 Views)
