External calibration of cRIO-9203 - How install nilvaiu shared library?
I am attempting to use the DAQmx utilities to do external calibration of a 9203 module, using LV2012 on a Windows 7 host machine connected to a cRIO-9025 controller with a 9118 backplane. When running something very simple, such as a VI that contains just the Initialize External Calibration VI, I get a message that says:
"DAQmx Initialize External Calibration.vi was loaded with errors on the target and was closed. LabVIEW: Failed to load shared library nilvaiu.*:DAQInitExtCal:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target."
I have reviewed the options for installing software under MAX, but I don't see anything that looks promising. I do see that there is a nilvaiu.dll file on my host machine, but it is unclear to me if I should copy it to somewhere on my target.
Any thoughts on how to put the proper library on my target?
Thank you for your assistance.
-Chris
(2,759 Views)
Hello Chris,
Unfortunately the cRIO-9025 does not support the DAQmx driver so you would not be able to use DAQmx functions such as DAQmx Initialize External Calibration.vi. or install this driver on the device.
Jose R
(2,721 Views)
