External code - difference between deploying and building application
I am using a 3rd party databasing system to store data recorded by a cRIO setup. To do this, I have compiled the necessary library for VxWorks and have instaleld it. Everything was working great with LV 8.6 / RIO 3.0.1, however recently I upgraded to LV2009SP1 and RIO 3.4 to solve other issues I was having. Now my external code does not complete in time when I build an application, however when I deploy the vi using the run button in LV, then everything works great. For example, I timed one piece of code:
Application     107 ms avg
Deployed VI    10 ms avg
My question is, what is the difference between calling the code in an application versus in a deployed vi? I would think that they would behave the same as the library they are both calling does not change. Any thoughts?
Jon
(3,211 Views)
Hi Jon,
How have you tested the timing of the external code?  One thing to try, if you haven't done this already, is to create as simple a VI as possible that uses this external code.  Ideally, this would be one call to the DLL and timing code around this call.
Jared S.
Applications Engineering
(3,184 Views)
Jared,
My code runs in time under LVRT 8.6 /RIO 3.0.1 and also when deploying it under LVRT 2009SP1 / RIO 3.4 . I have created a workaround for this problem by just dumping all of my raw data as a 2D array to the server and having a local program there sort out the diferent channels, the execution time is still higher than I expect, but is more than suitable for my task.
Jon
(3,172 Views)
