External trigger to read DI port on a M-serie DAQ
Hello
I want to read a digital signal from a custom build high resolution spectrometer.
Each spectrum is composed of 2000 channels * 12bits.
Each channel information is sent one after the other on a 12-wire bus every 6.25 us.
Two more wires are used:
- One for the channel clock (every 6.25 us (160 kHz))
- One for the spectrum clock (approx. every 2000 * 6.25 us = 15 ms (70Hz))
I am using a M-Serie 6224 DAQ board with Labview 7.0 and DAQ-mx 7.3.
I wired
-the 12 bits D0-D11 on the port0/line0:11
-the channel clock to pfi0 (port1/line0)
-the spectrum clock to pfi1 (port1/line1)
Now, in the vi,
what i wanted to do is to use the channel clock (pfi0) as an input for the sample clock to read the digital inputs.
This works fine. I can get my information, but not synchronized on the beginning of the spectrum.
The other thing that i wanted to do, is to use the spectrum clock (pfi1) as an input for the digital trigger in order to start reading the data each time there is a falling edge on this input (begining of the spectrum).
But as soon as i plugged the DAQ-mx trigger vi, even if it is set to input:none, there's an error:
Error -200452
Specified property is not supported by the device or is not applicable to the task.
Start.TrigType
But, the DAQ-mx trigger vi works fine when input task is analog
So now my questions are:
Is it possible that M-serie boards cannot read digital port when an external trigger is used??
If yes, where is my mistake ?
Otherwise, are there any workarounds ??
I hope I was clear enough so that someone can help me.
(2,505 Views)
First issue is to set up a trigger for analog inputs. Because of correlated DIO, the timing will be the same on anolog inputs and DIO. Look at this example.
The second issue is to update your NI-DAQ driver to 7.4.
Isabelle
Ingénieur d'applications
National Instruments France
(2,497 Views)
