Extract Information from XML using Xpath
Posted a Query in TestStand as it is related to TestStand report but then as i am using LabVIEW to Extract the XML Value Sharing the same post here
Please do needful
https://forums.ni.com/t5/NI-TestStand/Extract-Information-XML-Report/td-p/3777550
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 1 of 1
(2,840 Views)
