Extract and Set Icons
I found that VI Methods >> Set VI Icon allows you to programmatically set
the icon at least using Labview 6.1. However I cannot find a way to
read/extract the icon from a VI.
I found an Icon Extractor example vi at www.mooregoodideas.com but this
parses through the actual file, and that doesn't seem to work for VI's
within LLBs.
Is there a cleaner way than parsing through the actual file? I would have
expected a corresponding VI Property to read icon but I can't find it.
-joey
(2,854 Views)
joey,
the other way is to print VI to HTML and read the icon from the picture file generated, which is not cleaner than that Icon Extractor tool. There is no VI property to read the icon, only one to set it.
LabVIEW, C'est LabVIEW
(2,854 Views)
For a running VI, you can always capture that part of the front panel,
and save to a bmp file. See http://gtoolbox.yeah.net
Joey Oravec wrote:
> Hi,
> within LLBs.
> Thanks
> -joey
(2,854 Views)
