Extract color pane error
The actual vi "dilate erode2012" works fine. I tried to use their logic to develop my program. Can you please help me program the code to suit my requirement." use the dilate erode technique on images saved in a folder instead of acquiring from camera and save the output images in another folder.
Message 11 of 13
(552 Views)
Depending on the images on disk, it is possible that you cannot use the function "ExtractColorPane" at all...
A 8bit grayscale image does not have a color pane for instance....
I would expect this function to work best with RGB images.
Norbert
Norbert
Expert: Geometry
Message 12 of 13
(549 Views)
The images that are saved in folder are color in PNG format.
Message 13 of 13
(547 Views)
