Extract plane from a image
Hi, can anyone help me with this how can i extract the rgb plane from an image.
I need extract the red,green and blue plane from an image and show them in a vi.
I have a vi that extract the turn into the grayscale from a color image.
Message 1 of 9
(4,678 Views)
On the graphics palette is a color to RGB VI.  Take your 1-D array of image data, autoindex it into a for loop.  Wire out the R, G, B values through an AutoIndex tunnel.  Now you will have a 1-D array for each of those colors of the image data.
Message 2 of 9
(4,670 Views)
I did not understand well, could you explain me better in a vi
Message 3 of 9
(4,666 Views)
Forget that last message.  Color to RGB wasn't doing what I thought it was.  I realized your image data already as the R G B components coming out of your decimate array function.  The 1st 1D array is Red, the 2nd Green, the 3rd Blue.  See the attached block diagram.  If you take the red array and interleave that with two arrays full of zeroes of the same size, you get a red image back.  Likewise for the green and blue 1-D arrays.
Message 4 of 9
(4,661 Views)
could you send me the vi please.
Message 5 of 9
(4,656 Views)
It looks like you are using LV 8.0?
Message 6 of 9
(4,654 Views)
Hi, thanks for your help. I need one more thing of you to help me.
I need load a image , any size, and automaticly resize the image to his original size.
The vi must load the image when is execute it.
Could you help please
Regards david
Message 7 of 9
(4,652 Views)
I'm not sure what you are asking by this question.  In the top part of your code, I think you are already doing this.  You are reading the attributes of the image and setting the boundaries of those 2 picture indicators to math.
If this isn't what you want, than please explain what you mean by its "original size".
Message 8 of 9
(4,602 Views)
Hi David,
if you want to have your gray picture in the original size, then you can use the "Interleave 1d Array" function. In gray pictures R,G and B have the same values.
Hope it helps. Mike
Message Edited by MikeS81 on 06-16-2008 04:19 PM
Message 9 of 9
(4,600 Views)
