Extract unique data from column
How do I go about extracting unique non-zero data from a column based on data in the first column.
In the attached CSV file, the data looks like:
Cold Start Test @ 22.4 °C
cold start #1
index Start type Test1 Test2
1 cold start 46.67 491.394
2 cold start 46.67 491.394
3 cold start 0 0
4 cold start 0 0
5 cold start 0 0
6 cold start 0 0
26 cold start 0 0
27 cold start 0 0
28 cold start 70.17 24.948
29 cold start 70.08 24.948
30 cold start 70.08 24.948
cold start #2
1 cold start 72.42 24.948
2 cold start 0 0
3 cold start 0 0
4 cold start 0 0
5 cold start 0 0
6 cold start 0 0
7 cold start 0 0
... (see attached csv file for more details)
How can I go about getting the non zero numbers from column 3 starting after index 4?
Thanks!
(1,993 Views)
Hi hiNI,
  • Read the CSV file as array of strings using ReadDelimitedSpreadsheetFile.
  • Find the row with "index=4" and continue to use the ArraySubset after that row.
  • Get column 3 as 1D array.
  • Use an autoindexing FOR loop with a conditional output tunnel to filter any string elements different to "empty", "0", or "Test*".
Now you get all non-zero values from column 3 - you may filter for "unique" elements when needed.
(1,951 Views)
@GerdW wrote:
Hi hiNI,
a set will filter automatically all unique values, when you add them into the set
and it will sort  in an ascending order
Spoiler
(1,940 Views)
