Extracting cursors values
This is a question for Alain
The value of the resistor is equal to the Y value of the Z11re trace and the capacitor or the inductor value are derived from the Z11im trace.  Inside the Event Structure, the case 0 and 1 are connected to the same Y cursor value???  How do you tell the case structure to use (in case 0) the Y of the Z11re trace and in case 1 the Y of the Z11im trace?
The calculated values seems right???
(2,922 Views)
...it must be defined with CursIdx! but how to see the properties or how to see the set up of this?
(2,916 Views)
