Extracting elements from array X where the elements are specified from another array Y
Hello All,
I have an array X (say 10 elements) and an other array Y (say 3 elements). I would like to make a new array with the elements [x(y1), x(y2), x(y3)]. How do I do this most efficiently. In my problem the array sizes are large.
Karthik.
(2,954 Views)
See the attached subvi I made to do that for floating point values. The basic idea is to run both arrays into a For loop, but only auto-index on 'Y', the array of indices. Also use auto-indexing to generate the output array.
-Kevin P.
(2,954 Views)
