Extracting matrix and array from .dat file
hi all,
I need to know how to extract matrix and array from .dat file. I've been searching in code examples, but I couldnt find enough help.
In attachment I have a .dat file (can be opened with notepad), and I need to make intensity graph from x, y, and dc.
x values are between BEGIN_X and END_X
y values are between BEGIN_Y and END_Y
dc values are between BEGIN_DC and END_DC
This is what I try to do to read the data first. But when I need to read them all (far bigger index for FOR loop), it needs longer process time.
I think there might be alternative way which more efficient to load this data.
And then I need to get the values of x, y, and dc and build them into array and matrix, so I can put them into intensity graph.
Any helps are really appreciated.
Yan.
Message 1 of 9
(6,760 Views)
Hi!
The file shouldn't be read as a binary file, since it's a plain text.
Try using "Read from text file" vi and place all the content in a string (the file is not very large).
After that it's just a lot of parsing.
Marco
Message 2 of 9
(6,746 Views)
Hi marco,
1.With using read from text VI, I'm good to go? I think I need to use while loop instead FOR loop.
2.How to split two values with "tab" or "space" as their separator?
regards,
Yan.
Message 3 of 9
(6,743 Views)
Simply use the Read From Spreadsheet File.
Message 4 of 9
(6,738 Views)
Hi Dennis,
I would prefer to read the file a single string,
split it in the different sections and convert each sections in its matrix
Marco
Message 5 of 9
(6,720 Views)
Thats fine. Be sure to post your code to the rube goldberg thread when you are done.;)
Seriously, you duplicate what is already in the Read From Spreadsheet?
Message 6 of 9
(6,714 Views)
Well, I don't like the absence of error out of "Read From Spreadsheet".
Moreover in this case the file is not a matrix,
but a sequence of 3 matrices and 2 vectors, so maybe it's worth a custom parser.
Marco
Message 7 of 9
(6,710 Views)
hey guys,
this is what I got at the moment, I got the matrix and array out of the string. But I still have problem to spread them into the graph.
regards,
Yan.
Message 8 of 9
(6,698 Views)
Marco
You could always modify that VI to bring the error out.  Just make sure to save it as your own VI someplace else...
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(6,694 Views)
