Extracting time from dynamic data
Good morning,
I am acquiring a voltage from a myDAQ system. Basically it consists of a sinusoidal 6000Hz pulse during 50ms repeating approximately every 5 seconds.
My objective is to get the exact time position of these pulses, in other words the time corresponding to each pulse.
I am using a Tone measurement of the dynamic data and, in case it finds a 6000Hz signal, get the time from the dynamic data and store it somewhere.
This works, but I can´t get the corresponding time. I am using the "Get Waveform Time Array" vi but it outputs always the same array, apparently the whole Time array.
I don´t want to use the ms timer as I am hoping to get a higher resolution of time (5 microseconds) from the 200KHz sampling.
I believe I am confused about waveforms andtime management. Do you have any idea?
Thank you,
Message 1 of 1
(2,579 Views)
