Exxotest library MUXdll.dll call with LV2015
Hello:
     only post here for qurey because can't find any usage information on net, even on exxotest homepage.
Does anyone use muxdll.dll from exxotest with labview? I worked out a vi works with 2C2L but not with a 4C4L card.
(3,776 Views)
a simple case will be very helpful, does anyone have this experiences?
(3,564 Views)
@johnnnywang Did you success to control the muxdll.dll on any labview?
I see you have LIN initial on another topic.
Do you willing to share the library you use with this dll?
It is very difficult to get the example source code.
please set this as ANSWER or KUDO this post, if it help you.
(1,607 Views)
This is the documentation to it: https://exxotest.com/wp-content/uploads/2018/01/en_User-manual-EXXOTest-Muxdll-library.pdf
It looks fairly complete about what the different functions would do and the necessary function prototype to configure the Call Library Nodes for them. Of course you need to understand some C programming to read that information correctly.
Rolf Kalbermatter  My Blog
(1,590 Views)
@rolfk
Example is the LinSendMsg command.
How to send the hLinMsg code to dll?
(1,564 Views)
It would appear that the manual doesn't document the structure datatypes in detail. Instead you would need the according header file "refmux.h"  that should be installed onto your system with their “Exxotest Driver Kit and Utilities" software installer.
(1,551 Views)
it looks very complicated to follow the pdf.
I do not agreed if it fairly clear.
I think it would be good if Exxotest company has the example script in variant program.
(1,546 Views)
