FFT Power Spectrum and PSD - Max hold
I have a problem with FFT Power Spectrum and PDS VI - I would like to see the max hold values displayed on the spectrum, but the only options in the cluster "averaging parameters" are "peak hold". Is it the same? Previously I used "Spectral Monitoring (Interactive) VI", but the peak hold values on the spectrum were not correct - I noticed that this VI uses "FFT Power Spectrum" and not "FFT Power Spectrum and PDS". Is there any difference? Can I safely replace "FFT Power Spectrum VI" with "FFT Power Spectrum and PDS VI"? Or do I have to add something to the cluster "averaging parameters"?
Thank you in advance!
(2,608 Views)
Accepted by topic author Maximinus
Hello
Check this link  ¨"Difference between Calculating Power Spectrum and Power Spectrum Density of a Signal"
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015A5tSAE&l=en-US#:~:text=A%20Power%20S....
(2,483 Views)
