JB,
To help you, we need some help. Specifically, some specifics about your application.
How are you acquiring the signals from your spinning objects? What is your sampling rate? Are the signals sinusoidal, pulses from an encoder, something else?
What did not work? Did you not get any spectrum, was the frequency wrong, was the amplitude wrong, was the resolution poor?
If you post your VI with some typical data saved as default (because we do not have your spinning objects), someone will probably be able to help you.
Lynn
