FFT Spectrum (Mag-Phase) unit
I used the VI  "FFT Spectrum (Mag-Phase) " for 1 Chanfor 1 channel with input data in V.
The magnitude seems to be in volts-rms (Vrms).
Is it possible to have the result of the magnitude in V?
I have seen different topics about that, but no clearly reponse.
  Regards
  Julien
link to LabVIEW help
(2,797 Views)
Hi Massif,
Please Read the following KB - What is the definition of root mean square (RMS) voltage? [link removed; article no longer available]
Here it mentions how you can convert the Vrms value to a V peak value.
I have attached a small VI which you can use to do this conversion.
Enjoy.
Message Edited by Kabul on 06-10-2008 01:09 PM
(2,779 Views)
   Dear Kabul,
Thank you for your answer.
I understand all now.
(2,765 Views)
