FFT math question
When I run the Labview Power Spectrum Measurement.vi, I know on the X axis the peak will appear at the frequency of the signal, but what are the units they are using on the Y azis to determine how high the peak is going? Thanks.
Intern NSWCCD Carderock.
(3,355 Views)
I'm not certain, from my fairly short examination of the vi you are using, but in the signal analysis palette the power spectrum vi output is described as " If X represents actual measurements in volts, the VI expresses the normalized units of the output sequence Power Spectrum in watts on a 1- basis" so my guess is that the one you are using is probably the same.
If I get a few more minutes later I'll try and look deeper.
Putnam Monroe
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,347 Views)
I'm still not sure I get what it's doing. If I pass in an Amp of 10 V at 200 htz I get a peak at 200 htz which goes up to 50 on the Y scale. I dont really understand how this Y value is computed, anyone know? Thanks.
(3,326 Views)
From the Auto Power Spectrum help "Power Spectrum is the single-sided power spectrum in volts rms squared if the input signal is in volts".
If you are putting in a sine wave of 10V the rms value will be approximately 7.07V. This value squared gives you 50.
Putnam Monroe
Putnam
LabVIEW Champion
(3,317 Views)
Thanks, I was doing some incorrect math on my RMS values.
(3,309 Views)
