FFT measurement from a spreadsheet file
At the moment I'm doing research to brainmeasurements. People in my unit did some measurements at a sample rate off 25 Hz. I'm reading the data that they collected by using a  "read a spreadsheetfile" . What I want too do now is to perform a FFT on the data that they collected. The data that I try to analyse is 1 signal at a time. The range that I'm interested in is from 0 till 1 Hz. So we are looking at the signal in the very low frequentie range. I tried some things like using a spectral measurements application but than I don't get a nice FFT out. I tried too make the data running by sending the data trough a for loop. This showed a total different view. But now we had also negative amplitudes in some frequenties. So looks like this it not the way.
I posted also some screenshots. In the file frontpanel 1 you see the original signal. In 2 you see a selection that was taken out the original signal. and in 3 you see the 2 different FFT's that I tried.
Can someone give me an idea about what I'm doing wrong??
(3,610 Views)
Could you post your data and some code?
Bas
(3,578 Views)
This VI represent my problem.
Thanx allready for responding.
(3,566 Views)
You have a very large DC offset in your data which tends to mask the variations. Subtract it out before doing the spectral analysis.
Lynn
(3,535 Views)
Thank you for helping with that problem. But then I have another question. If you look at the X-scale, what does the numbres represent. Is it the time, is it the frequentie and why doesn't it continue after 0,5?
I ask this because if you look at the FFT you see a peak representing everytime after I geuss a few Hz, but the amplute is half the value off the peak before this. Maybe also a solution for this problem?
Thank you again.
(3,499 Views)
The X-axis in your data appears to be sample numbers (0, 1, 2, ...). The Spectral Measurements VI expects a waveform datatype as its input. The waveform datatype contains a time increment component (dt) as well as the array of Y values. If you feed it the proper dt, it should give the proper frequency values on the output. When I told it the sample rate was 25 Hz, the X-axis vales no range from 0 to 12.5, as expected. The first peak is just above 1 Hz.
Lynn
(3,483 Views)
Thank you very much, you helped me a lot.
You're a star.
(3,475 Views)
