FFT out of simulation loop
Hello
I have a problem how to plot FFT properly. I want to make a simulation of dynamic system and I have tried memory and collector to get signal out of simulation loop but every time the plot happens to be incorrect. I have no idea what I do wrong. Here I attach a simple example.
Simulation time is 2 s and although sine frequency is 25 the plot shows 50.
Thanks in advance.
(1,242 Views)
Hi Tairux,
there are several things wrong:
  • You only attach images instead of a VI. We cannot debug/edit/run images using LabVIEW!
  • Why do you need to create an array using BuildArray just to index the first element of that array? This is called Rube-Goldberg…
  • You only send an 1D array to the FFT function: there is no timing information in your data! I also don't see anything in your code related to timing informations…
(1,213 Views)
Right, my bad. I will attach my VI. Besides that I also tried with "Spectral Measurements" block and "Spectrum (Mag-Phase)" block but I am not sure which is best for my application. I mean I don't know exactly how to handle getting signal out of simultion loop to make FFT function work.
Thanks for reply.
(1,207 Views)
You want to simulate a signal.  LabVIEW has a data type called a Waveform that includes three elements -- the time (t0) at which the data were acquired, the sampling interval (dt), in seconds, between samples (so it would be 0.001 if you are sampling at 1 kHz), and an Array of Dbls (Y) containing however many Samples you acquired at a time (for example, sampling at 1 kHz for 1 second would give you an array of 1000 samples).
When you analyze a signal to get Spectral Data, you need to "scale" the results according to the sampling Frequency (or sampling Interval, 1/f).  If you look at the Block Diagram Palettes, you'll see one called "Waveform".  Look inside at Analog Wfms/Generation and choose "Simulate Sig", an Express VI that will simulate a Signal for you that you can feed into your Spectral Measurements Express VI.  This should work better for you.
Bob Schor
(1,168 Views)
Hi Tairux,
see this after reading Bob's message:
You should know on your own what is best for your application!
(How should we know that?)
(1,152 Views)
