FFT power spectrum formula
Hi
Can anyone please tell me the formula used in the LabView for calculation of FFT power spectrum in decibles?
Thanks in advance
Pramod
(5,712 Views)
quick search
search the forum and post if any specific help needed.
(5,710 Views)
What is your problem. Do you only have labview base, or is it something else.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(5,707 Views)
Hi
I have already searched but didn't got the exact info.
In linear scale,         power spectrum=fft(X)^2  where X is time series.
In decibles scale,    power spectrum=10*log10(fft(X)^2).
I am not sure whether the above formula in decibles is correct.
I used LabView for spectral analysis. I need to do the wavelet analysis using Matlab. In Matlab, I will require the subplot of fft power spectrum. I can do that if I know the exact formula in decibles.
I will appreciate if someone will tell me.
Pramod
(5,692 Views)
The output from the power spectrum is (amplitude value(rms)^2)/2 for non DC values and DC^2 . To find rms value of a sinus wave you divide  with square root(2). The decibel (dB) is a logarithmic unit of measurement that expresses the magnitude of a physical quantity (usually power or intensity) relative to a specified or implied reference level. Take a look at this site for more. http://www.sengpielaudio.com/calculator-db-volt.htm
(5,667 Views)
Hello!
Have a look links below:
http://www.ni.com/white-paper/4278/en/
https://www.ni.com/docs/en-US/bundle/labwindows-cvi/page/advancedanalysisconcepts/power_spect.html
http://www.ni.com/product-documentation/54619/en/
Formulas are written both for power spectrum and amplitude spectrum.
(3,669 Views)
