FFT
Hi everybody,
I'm writing this post because I would like to know if there was a way to save the results obtained by a FFT.
I'm acquiring a signal with a DAQ and performing a FFT to see its frequency components.
I have no problem to save the data coming out from the DAQ a file  with the function "write delimited spreadsheet", but when it comes to the FFT it does not work with the same method (obviously).
Is there a way to do it ? Thank you so much
Marco
(2,964 Views)
Hi Marco,
the pink wire is a cluster: you can get the elements using the Unbundle function.
Then it becomes easy to save the FFT result...
(2,955 Views)
I used the Unbundle function, then I created an array with the "build array" function and plotted it to see if everything worked.
It does work in Labview, even when I modify the input parameters of the sines components, the FFT is accurate.
The problem is when I want to upload the data and plot them in Matlab. Basically is like if the file saves only a part of the results but not all of them. If I modify the inputs after the Labview routine has started, it does not show them.
The Matlab code is the following
Could you help me out? Thank you so much .
Best,
Marco
(2,928 Views)
Hi Marco,
I'm not an expert in Matlab - you are asking in a LabVIEW forum…
You build an array of those f0, df and Y[] data in LabVIEW: when you load that data in Matlab you should also use the first and second value (f0, df) differently then the Y[] data after them…
Two notes:
  1. It doesn't make sense to create a plot with prepended f0 and df values!
  2. Use UnbundleByName as it creates much better selfdocumenting code!
(2,882 Views)
