FGEN Question
Hello Everybody
I have a PCI NI 5412 that I intend to use to generate a TTL compatible squarewave signal of 32 KHZ and 50% duty cycle. The trouble is that 5412 does not allow me to offset the output DC component with more than  0.25% from Vpp value (e.g for 2.5Vpp output the admissible DC offset is up to 0.625V). This limitation prevents me from generating a TTL (0-5V) square signal.
I there any way of setting output DC offset to more than 0.25%(Vpp)?
Thank you for your time.
(3,006 Views)
Hi Nick,
Someone else recently had this same question.  Travis from NI gave the answer here.
http://forums.ni.com/ni/board/message?board.id=310&message.id=572&query.id=24800#M572
Brian
Message Edited by BrianPack on 03-29-2006 04:57 PM
(2,999 Views)
